Re: Screen Vs Magnus
When the magnus is working correctly its a dream come true. We have a Magnus 400 with an auto cassette loader and an inline processor. We run up to 80 plates a day when we are doing good. There are only three prepress people in our dept. so its nice to have the plater take over and just spit out plates. In a perfect world we just que up the plates at the end of the day and come in the next morning, quickly QC everything and pop em' in the bin for the pressman.
Now having said that. Here are some issues,
1. Auto cassette loader pinchers do not always pick up slip sheets (regularly causing an error which stops all plating)
2. Slip sheets in the punch area that were not moved into waste receptacle (regularly causing an error which stops all plating)
3. Plates double loading with slip sheets... No error and its bad news when it comes out the other side.....clack, crunch, bang, bang.... (This rarely happens..but it has happened.)
4. Slip sheets clinging to the plate after loading....going through inline processor and plugging pump and getting paper in the developer, water and gum rollers....(Periodically causing an error which stops all plating)
5. Hot spots due to humidity or laser intensity which are not always caught and wind up on press and piss pressman and director of operations off. Bummer......that one is.
6. Plates double punching and getting stuck in the punch mech, (This rarely happens..but it has happened.)
Also dialing in the laser and getting the diodes set correctly is key. We tried using the 10 micro staccato and the pressman just bitch. We also had issues with banding but we did remedy that,
We have had our system up a little over a year and we are still dialing it in.....
