shingling, creeping
Re: shingling, creeping
We usually cut down some of the paper stock to be used and fold it down and then measure it.
If you know the width of the paper in thousandths of an inch you can figure it by taking the total number of pages and dividing that by four. Multiply that result by the thickness of the paper. For example if your paper is .003" thick and your boo is 200 pages it would be 200 / 4 = 50 * .003 = .15"
Hello Steve,
If you are the Graphic Designer then ask your printer, but if you are the printer there is no substitute for making a dummy i.e. take the required number of sheets and put them through your (or your finisher's) folder, but switch off the trim! When you measure from the outside edge of the first page to the outside edge of the inside page this is your creep (shingle) measurement you enter into your software.
I have come unstuck in the past using a creep generator as it does not take into account the tolerences in paper manufacture and what the folder does - some folders are neater than others and some drift more than others.
Regards minch.
Minch,
Our Design Services Department use to provide the creep for newsletters, but switched from quark to indesign and never let me know that they don't provide the creep anymore, So on the last newsletter I built the inside pages were almost cut off.
I'll give your suggestion a try, and thank you for your help in this matter.
Steve
Hi Steve
Here is the PC equavilant that we use, it is a creep calculator set up in Excel with the calculations for the total creep measurement that you put into preps as well as the page increments in millimetres.
Hope this helps
TC
Edited by: Tony Collins on Jun 10, 2008 7:09 PM
I am interested in this Excel calculator, but I can't find the link on your reply.
Could you re-send it?
Thank you in advance
Edited by: Adriano on Jun 11, 2008 5:24 AM
As an FYI for anyone using the Spine Calculator... the numbers it generates are not the right numbers for creep.
It generates a calculation that is the thickness of the books spine... not the creep amount that would be 1/2 of the amount this utility generates.
An example of the difference follows:
Using the spine calculator... choose 40# White offset and opaque
It generates a thickness of 0.0025
if you enter 200 pages it generates a spine width of .25. This is the actual thickness of the book.
Using the proper calculation
200 Pages / 4 = 50
50 * .0025 = .125. This is the actual creep
If you use the calculator... cut his number in half
John
Since I couldn't find a decent Shingling Calculator... I created my own.
If anyone wants it... go to:
www.montesi-consulting.com/downloads.htm
It is version 1.0.0. So if anyone has any suggestions for improvement... let me know.
Currently, it is only for the PC... If I get a chance in the future I will create a Mac based utility that does the same thing.
Enjoy
John
Thanks for that. Is there a way to add my own paper sizes in addition to the ones you have in there? I know I can enter a custom value but it would be nice to be able to add the paper we use regularly into the menu of selections.
As for permanently adding your own sizes... Not yet... Possibly a version 2.
I threw both of them together yesterday afternoon and evening.
I just happened to have a day off to do it.
Depending upon how many different stocks you use... I can easily add them if you send them to me.
Just drop me a line through the website.
John
In your formula (pages/4)-1)*thickness, don't you have to make this calculation for each signature? on a 96 page book you would need to make the calculation 5 times, excluding the outer signature. I think the formula is great, but it only accounts for final page count.
It's true that it only calculates the total creep for what in theory are the center pages.
If you have a program such as Metrix you will find it automatically applies the amount given to the center 4 pages and it incrementally uses smaller amounts as it moves towards the other side of the book.
If you use Preps... you can apply the amount given or split it between inner and outer spreads.
For now it is a simple start... that I threw together in a couple of hours...
I am currently planning a version 2 which will allow you to enter your own paper stocks... which it will keep in the list
Possibly... I will be able to have it spit out a list of what each of the spreads should ultimately be moved.
Bear in mind... I'm not a programmer... so I apoligize that it isn't happening as fast as I would like.
John
Hi Joe,
I just posted a version 1.5 of Shingler. It is half way to what you want.
It now creates a file called Shingler.plist if the User>Library>Preferences folder
If you edit this file with a text editor you can add your own papers and sizes...
The format is a line for the name... and then a line for the size...
If for some reason you corrupt the file... just delete the plist file and it will be recreated at launch time with the default paper thicknesses again.
This is only for the mac version at this time... more people were downloading it than the PC version.
Eventually, I will have both versions with equal features.
http://www.montesi-consulting.com/downloads.htm
John
