Spot colors won't turn into process...
motormount
Hi all!
I'm using a couple of group templates in which i've turned on the ''Map all spot colors to process disregarding job settings'' option on color conversion.
Today i printed a job using this template,didn't check it,and i 've got me 5 plates!!!
I checked the prepare file sequense and the ''Map all spot..'' option was on!
I changed the spot color to process manually in the job settings,put out the job right and then i created another job with this option(map2process)
Again every document i tested produced pages with spot colors!!!!
The teckies told me that they should give it a closer look,but is there anything i could check out first on my own?
That's Prinready 3.5 on a xp sp2 machine!
Thanks in advance,
Antonis.
I figured out a ''solution'',deleting the group and sequence templates and using the backups i've got.
I'm keeping backups because every now and then when i'm creating a job and assigning a sequense template to it,some java error message pops out and the template cannot longer be loaded-except for this time where it was loaded but din't worked right...:mad:
The tecks told us is due to our local network-but can't solved it out because they aren't the ones who putted the network together-,i wonder if anyone has come up against anything like this! :confused:
