jeffrbauer
I am trying to print a spot gloss image on a black uncoated cover that looks similar to a UV gloss process. I will be running it on a conventional Heidelberg Speedmaster CD74.
I don't have much experience with coatings and varnishes. I have used the AQ unit to flood coat items and I have gloss and dull coating supplies though I have never used the gloss. I have used an overprint varnish on a white uncoated stock and realized it doesn't show. (I don't know if it would be different on a black uncoated stock)
I have thought about a few different approaches and I'm not sure how the press sheet would turn out. Time is not a factor so multiple passes as well as polishing with impression rollers are possibilities.
1. Just run a high gloss varnish.
2. Run a high gloss varnish and flood coat with dull AQ.
3. Run a dull gloss varnish and flood coat with dull AQ.
4. Run a gloss gloss varnish and flood coat with gloss AQ.
5. Run a dull gloss varnish and flood coat with dull AQ.
Or do the same as above in with AQ first and another pass with varnish?
Do I need to look for specifically for overprint?
Thanks for any help.
