kaiserwilhelm
Pitstop Pro now as the ability to look for a graphic and detect if it is a known graphic.
I want to do the following and am wondering the feasibility. You all might shoot a hole in it quickly before I waste time.
Say I have five dies. I make five 2D barcodes say .5 x .5. I go into Illustrator and on the outside of the die I place 2D#1 on die#1
Identical X and Y I now do the same for 2-5
I then have a Switch flow where I have it use an EAL to look for 2D (graphic) number 1. If it finds, it goes down path 1. Etc, etc.
The idea here is that I do not trust the die that is put onto the run ready PDF. IF I can "see" the 2D then I know that is DIE#1.
*NOT looking to read the contents of the 2D. Looking at the 2D as a graphic only
