UV Gold Coatings
It would be recommended to achieve the best adhesion.
Oh.... and best of luck to you when you go back to clear coating. There will be gold in dem darn hills for some time to come. Good luck!
D
maybe a hit of yellow under the Gold used as a primer might work for you and Mr D is correct if you run Gold through your coater you could be a long time cleaning. Maybe better to get a Perastaltic hose pump and run new lines just for gold if this is something you plan to do on an ongoing basis.
Bottom line rmbob, PRINT your golds and don't employ them as coatings. You, your operation and all involved will be better off in the long run. Trust.
D
