Hi all
Ok let me paint a picture.....
Im the PrePress Manager ( I have never operated a press !!!)
3 Heidelberg Press (2 x 102 1 x XL105)
No Print Manager only Print Team Leaders which work on different shifts..so no one taking full responsibility for the the Presses, because the Team Leaders are actually on press printing Jobs.
We use ISO12647 Target curves for Coated (FM20) and Uncoated (FM25)
We use image control to set the correct LAB Values and achieve these consistently (so no problem there)
We proof to Fogra39 via epson
I want to Move back to 200 screen for Coated and 150 screen for uncoated. Why...because to achieve ISO12647 dotgains consistently, FM screening is not the way Forward, what I have found any change on press can totally throw any calibrations ive done and this can cause us not been able to achieve consistent dotgain. (Hence we are always running print trials to correct this).
If we had a print manager to monitor the presses and a daily basis to check the following:
Blankets, Press Chemical, Ink, sequence, Press chemical etc to make sure these conditions are the same to when I calibrated, then maybe we stand a fighting chance of been consistent.
From my experience AM screening is more stable than FM Screening.is this correct ?
We need to achieve ISO certification the end of the year..im been told staccato is not included in the ISO certification.
Hope im making this all clear as Mud !!!
Any feed back would be great.
PS: Who can tell between FM and AM anyway....we dont print high quality work
Products - Greeting Cards, Commercial print and packaging
