[SNIP]
So i think that my criterias are:
the speed, the Jdf integration, the price.
I'm printing with 300 Dpi and I'm note using FM trame.
just a questin: do you think that if my CtP is producing an FM trame I'll be able to print it ? or I need a special printing machine?
You say you're currently doing 300 "Dpi" with your Prosetter. I assume you mean 300 lpi?
And you're considering doing FM. And you do magazine work.
So you should have already encountered any issues with high screen rulings with your current set up as far as plate imaging integrity and on press issues are concerned. Your own experience tells you whether violet is consistent and stable enough to do fine screens.
With a second order FM screen, like HD's Satin screening, at 20 micron the highlight dot is equivalent to an AM 1% dot at 120 lpi, or an AM 1.5% dot at 150 lpi. Lthographically it would be the same as about a 385 lpi screen - not that much finer than what you're using now.
That should answer Steve M's concerns. That being said, your success with violet and high screen rulings goes against every experience I've encountered.
So perhaps you should test HD's Satin screening with your existing setup.
Also, make 300 lpi and FM 20 micron capability a condition of the different systems you'll look at. Ask the vendors to give you reference sites that are doing this type of work for 100% of their jobs. Then contact those reference sites and find out directly what their experience has been and compare it to yours.
best, gordo
