Pro Digital Photos
Okay, I've read most all post about the 700 here and heard many opinions. I'm a photolab, and our 252 was our first 4 color printing machine and a huge learning curve as well. I've been thinking of upgrading as i felt this was an entry level machine and the bigger models would be an improvement all around, but I don't think that's true. I had a demo today with a 700, printed all my own work, on the papers I'm currently using on my 252. The quality seemed the same, a little disappointed, but expected. The auto duplex on the thicker stock was great (I REALLY wish it could do 300gsm). The fact that trays 1-3 hold 12x18 is GREAT. I had a sheet of 300gsm that jammed in one of the finishers all day, all the techs there couldn't figure it out. I also 'tricked' the machine to auto duplex the 300gsm, and it seemed to do fine, but i realize they will not support problems duplexing that thick. When I sent a bunch of manual duplex jobs, the 700 would stall out on side 2. Our 252 does this, but the 700 would sometimes never print the second side and had the cancel the job and send it again....that's not good if I had 1000 side ones and then had to cancel???
So I got the sheets back to my lab and had the cards cut and scored. I've always hated all the chipping and cracking with the 252 as I feel this is my only shortcoming against Indigo prints (which I do not think crack and chip like toner prints). Anyway, after I got these samples cut and scored, they were much worse!!! More cracking on the folds and at the cuts there was chipping, and not only that, the toner it chipped got all over the rollers in the machine, so the next job had lines of toner where I had cut the test sheets!!!
I was disappointed and don't know where to go from here. I think I want a 252 with the 700's trays and increased duplexing capabilities (while I'm dreaming, 300gsm auto duplexing) and the decurlers. I was thinking maybe the 5000 would be better for me, I can buy a used one for half of a new 700, but further reading has got me thinking I will not like the oil used in the fuser.
The biggest problem with the 700 tests was an uncoated 80# CVR sheet that is simply awesome on my 252, no cracking or chipping AT ALL. On the 700 the toner on this sheet almost just fell off... it was crazy. And even the other coated stocks would rub off when I was folding the cards on the crease. Is this the fuser problem I've been reading about. I guess the 700s fuser is not as hot for the low melt toner?? Or the faster speed it travels through it???
So I think I'm just going to live with the 252 and maybe upgrade to an external rip as that would probably increase productivity, but the auto duplex would do the most for me.
What are your thoughts??
