arossetti
Did you replace the Fanatney Rod?
We have been having to replace ours more often. With the switch from Japanese to domestic after the tsunami we have had trouble with Jack Links.
Tell your tech this
replace all developer housings with 5000 developer housings. of course put in Xerox 700 developer.
Xerox 700 developer housings have issues, all of them
Tell your tech this
Tell your tech this
Tell your tech this
We just had 5000 housings installed in our C75 and there is a definite improvement although our black is still screwed. Time will tell if these housings are better or not.. we've had new dev housings installed on a nearly weekly basis so far.
I guess we got lucky. Our C75 that was installed last week prints great. We put 40,000 clicks through it last week.
Did your issues appear after you had run for a while or did they start right off?
We are a refurb and resell business so we've seen this on many units. My thinking is either there were bad batches of developer housings out there or I know it's the same housing as the ones used in 242 252 260 model and being installed on 700 series. Any ways the 5000 housing works alot better. Run your machine as much as you can, "if it ain't broke don't fix it".
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
