Thank you for the answerWhat error? You need to provide specific details if you want specific answers. What paper size are you trying to run SIQA with? There are known issues on 13x19 paper with older firmware. Are you using the document scanner, glass, or both? Do the error screens give you any error codes? Did it always did this, or is the problem new?
Thank youAt your size, the old firmware issues are the most likely culprit in my experience. What firmware are you on?
Can you try using the document feeder and see if you get the same result? Also - look at the last comment in this thread: https://printplanet.com/threads/v180-siqa-alignment-adjustment.293665/
Make sure you're trying to eliminate the issues that person identified.
Before i don’t have problem with alignement with this size sheetStrange sheet size. Does the machine align ok with other stocks and sizes?
If so I'd try cutting your original sheet down to sra3 or a3 and try aligning that size and the alignment should be close enough for your original size.
It might be the SIQA needs to make an adjustment more than it's capable of.Before i don’t have problem with alignement with this size sheet
If i set it manually it can change after about 30 printing sheetIt might be the SIQA needs to make an adjustment more than it's capable of.
I've had it before where the skew went out more than the 2mm it can compensate for.
Ended up needing a tech to come in and manually reset the adjustment so it was back in range of SIQA.
If you manually adjust the settings can you get it set?
There is service manual in pdf format available. In the manual is described a series of adjustments for registration. Also what need to check on copier registration assembly and in others copier assemblies.If i set it manually it can change after about 30 printing sheet
Pls How can i reset the adjustment ?
Thank you
where can i download There is service manual in pdfThere is service manual in pdf format available. In the manual is described a series of adjustments for registration. Also what need to check on copier registration assembly and in others copier assemblies.
Send me mail = [email protected]where can i download There is service manual in pdf
Thank youSend me mail = [email protected]
