I am aware that the Versant 80 is old and I've gathered that it has a history of 2nd BTR issues; but, until I upgrade, I'm keeping it alive. It developed this defect several months ago. It appears every two or three sheets as a horizontal smudge. When it first occurred, I replaced the ITB Cleaner Assembly; that seemed to solve it for some time. But, it has now come back. Could it be related to the NCR, the 2nd BTR issues (mine is surely shot), or just a damaged ITB? Also, attached is a picture of the decurler roller; is all of the black stuck-on-toner a result of the bad 2nd BTR (likely from running so much NCR)? Can someone explain how a 2nd BTR issue causes so much toner build up on the back of the paper and bottom of the paper path (rollers). Is it because a rough 2nd BTR roller can't be cleaned effectively of waste toner?
Thank you for all of your help! I'm also open to suggestions for an economical machine to run my NCR on.
