Here you go.
Use Find function. It will return the starting position of string you are searching for, if the string is not found it will return -1. When any other value is returned you can then set the replacement string with your if statement.
Find (data to evaluate, expression your looking for, starting position [note 0 is the first character])
If (Find(|->[field1],"chips",0) = -1
|->[field1]
else
replacement string
If you are trying to replace "chips" with "tokens" but want to leave all the other text in the original string intact use the FindAndReplace Function.
FindAndReplace (data to evaluate, expression your looking for,replacement value)
FindAndReplace (|->[field1], "chips","tokens")
if |->[field1] = "gaming chips" the result will be "gaming tokens"
if |->[field1] = "gaming pieces" the result will be "gaming pieces"
if |->[field1] = "fish and chips" the result will be "fish and tokens"
Hope this helps someone.
t.
