Xmpie help
thebluesdude
I guess its like using a sledge to crack a wallnut but we regularly need to print databases full of different labels. How the hell do you get xmpie to fill a sheet with different ones?
The problem is the way the labels are laid up on the die cut sheets, I need to create an A3 sheet with all the data fields in position and then get xmpie to change each one of say 30 different types on one sheet?? All I can seem to do is generate a label sized document and have the multiples layout in the dynamic print sort them. Any ideas guys?
Cheers
Ron
I am not familiar with XMPie but I do remember someone telling me a way you can have different Layers print which would have different art on each layer.
Hope this helps.
When you are in Dynamic print, select the step and repeat option. Select your paper size and then select the cut and stack checkbox. You might have to play with the gutters to fit your particular template. That is about the extent of it. Hope that helps?
