Hey all, new to this forum. Its been over 12 years since I have ran an AB Dick and about 6 years since running a press at all. I have mostly been in prepress since. I have acquired an AB Dick 9870D which is newer than I am familiar with. 9840 & 9880 is the last I have ran. The feeding system is alittle "beefier" than previous Dickies I remember. The top forwarding roller is continually in contact with the bottom forwarding roller. On the right side the arm moves up & down slightly and not at all on the left side. This causes the paper to not feed in straight. On older versions we would just bend the arm on the left side just a little so the up/down movement matches from side to side. I know the roller should be moving up & down but is not. Does anyone know how to fix on this version? The arms are much too s****y to just bend.
Thanks PrintPlanet!
Thanks PrintPlanet!
