I have problem with Agfa Accuset1000, during send the job from TCP-IP
or Hot Folder *.ts
the Rip start buffering the Job and start sending it with high speed to Imagesetter the Rip counter start from 0 to 100% after that Rip Hang!,
during that Imagesetter control pannel appear "Rip Active 0C" Busy" message and no any job have imaged alo no film has been loaded.
I am replace the short cabel and imagesetter cabel but the problem still found.
Also replace other APIS Board from my friend.. OK normaly working.
Now I have problem in APIS Board, I am check all parts ICs,75als192 , 75als197 , All Resistance,Fuses,Capacitors and the lines connection all same as the New APIS no difference with new board detected.
The pin1 is connected to (U27)75als192 pin3...Ok same as New Board.
The pin2 is connected to (U18)75als192 pin14...Ok same as New Board.
But...
When you use the Ohmmeter the resistance between the Pin1 and the ground or the Pin2 and ground produces a resistance an infinite same as line broken.
When the opposite poles of Ohmmeter produces a 673 ohm resistance while the new Board 27 ohm resistance produces the same in both directions.
Please help me for repair my board.
Thanks..
or Hot Folder *.ts
But...
Thanks..
