Re: Azura plates run length issues
A few more notes about the conditions of the press and such to consider.
1. We tend to run the ink to plate stripes on the light side as the R300 tends to streak in solids with "normal" ink stripes. No ink roller with the exception of the water roller is set heavier than 3/16". We are running the factory specs for the plate cyl. at .004 over the bearer and the blanket is .002 over the bearer for a .006" squeeze. We started with Day 3000 blankets but now we use the Patriot blankets from Day.
2. It is not a particular unit. We can blank on unit one and two, print on 3 and 4 and still have the same issue.
3. This problem happens on the first side printed, NO press powder involved. In fact, when printing the 2nd side of the sheet the image wears at about the same number of impressions with spray powder.
4. The amount of coverage definately plays a role as the larger the solid the faster it wears. Offset stocks also seem to cause the plates to wear faster.
5. AGFA did send in their peoples to do a patch check with our chemicals. The only thing that seemed to effect the emulsion was a universal plate cleaner that we immediatly stopped using. (28 months ago)
6. I am not blaming prepress for the problem. I am saying that the plates that I chose to buy appear to be the problem, not the press or the stock or chemistry. One of these things is breaking down the plate but I alson think that the plate is the problem and it is time switch to a different plate. I was hoping to find others with the same problem and what they did to resolve the problem and it appears that bagging the Azura plate is the best coarse of action at this point.
I am wondering if the paper humidity and or abrasive residue from the paper, mentioned earlier by Lukas is the culprit. Having said that, I don't have the luxury of not running these stocks and the plates should not be effected so adversly by them.
Thank you to everyone for your input, this forum is a great place to tap experience.
David
David
