baum folder
hawk
i have baum folder 500 dc, it stuck paper, we took out it but and then it does not turn on, any budy has any knowledge about it...
Will it turn by hand? that troubleshoots the mechanics.
Is there voltage to the motor and/or a re-set for the motor?
Our folder the hand wheel is geared in with the rollers and it will turn over Even if the belt is off. Does the motor kick on when you hit the start button?
The motor clicks? We've gotten you as far as possible. Look over the entire motor for a push/pop reset. Disconnect the output drive (belt?) from the motor and verify that it does not run, try to turn the folder by hand with the belt off.
