We have a job which is set up in QuarkXPress 8.5 using FormsX and SecureX. This is for a check. On the top of the check, we have a pantograph created in SecureX which has a gradation from 80% to 20% PMS 564 U. Under this, there is a solid box with a straight screen of 8% PMS 564 U.
If I send "separations" from Quark to a local printer (Xerox Tektronix printer), the file separates out fine, with both fields appearing on the PMS 564 U plate. However, when I create a PDF X-1a then send that over to my spool folder, that's where the weirdness starts.
When previewing the job, the bottom screen is on the PMS 564 U plate, and the gradation on the top of the form shows up on the Cyan plate. We are completely perplexed as to why this might be happening. When we called the company that has been supporting us (who sold us the system) they suggested changing the PMS color, so we switched it out for PMS Pantone Blue, and got the same weirdness.
We tried exporting from Quark to EPS and PDF and building the imposition in Adobe Illustrator, and in the EPS case, lost the top part of the form entirely, and in the PDF case, the file took forever to rip (over 45 minutes) and put the top part on Cyan and the bottom part on the PMS 564 plate again.
We (of course) figured out that to get the job out, that simply changing the bottom color to Cyan would put both on the same plate, which is what we did, but I still would like to know what is causing the problem and if anyone knows of a solution for it.
Thanks so much in advance,
Jim Yarrow
Maccimizer
Jim Yarrow
Maccimizer
