For those Prinect/Cockpit users out there, anyone ustilising the 'booklet proof' template? I use it to run booklet/dummy mock ups from the layout and it usually works well. I am havinga great deal of trouble at the moment as it fails often and jams up the meta. It seems the double page spread pdf is submitted ok to the meta queue (you can even open this file and print directly to the HP5550 duplex laser) but as the file is managed through colourproof pro and i asume out through the print driver something goes wrong and it fails, usually with a error in device or error in mismatched size. Prinect handles all the sizing, layout and imp settings and should pass it through the meta queues and then onto the windows print spooler. It seems to have problems with jobs that have multi signa parts or perhaps combinations of printing style but its very hit and miss. Once it fails the whole meta jams up and any other devices also jam up and the meta needs to be restarted.
What other double sided proofing options are being used out there?
