C900 Questions
tshark
Does anyone know if you can run consecutive sheets through the C900 with the print command turned off? For example, a collated book that you want to run through the C900 for the purpose of utilizing the Ring Binder or stitcher. Thanks.
In short, no
In short, no
The only way that I know of is if you have the Cover Insertion Module, which allows for preprinted sheets to be fed post-fuser. But even then there's no way to do that without it being part of the print stream of a job. Sounds like you're trying to use the printer as an offline finishing device. The only C900 module that works that way is the Plockmatic booklet maker.
