Robert carter
walk me through aligning the chain delivery back up with the press on a 3200? PLEASE!!
Yes Sir, the CD is back on and operating. The problem now is that I am having trouble getting the image from the blanket cylinder to the sheet. I went all old school and put packing under the blanket and now it will print sheets. there is a problem with the leveling of the print and the latch lever keeps popping loose. Any help appreciated. Thanks Robert Carter.Hello Robert,
Korntucky sounds like a fun place. Did you have the skills to install the CD and time it etc? Do you have the service manual?
I have the manual. I was told that I had to drop the impression cylinder in order to get it back in time. I think that's where my problem lays. the arm that is attached to the NON op side is out of adjustment since I took it off to drop the cylinder. I really appreciate you helping me sir. The Lord will bless u for helping others.Do you have the service manual????? to show you how to set the level of the master and impression cylinder to the blanket? With the eccentric's? The blanket is fixed and the plate and impression cylinder pivot to make contact.
