Color issue with Ricoh 9100
I’m running into an issue running a Ricoh 9100. I’m running a 13x19” sheet. On the lead edge, the color is off. If I’m running the color red, the first 1 inch to 1.5 inch on the lead edge would be pink. The rest of the sheet runs fine. It’s only on the lead edge where the color is off.
We have a paper profile setup by copying one of the profiles that were stored in the library.
Im guessing this is a transfer issue or some sort but I can’t figure out which setting to adjust. Does anyone have any suggestions on what might be causing this?
My Ricoh rep just told me to "make changes to the transfer in advance settings one adjustment at a time until you get what you want."
Any ideas on what settings to adjust?
Dmiller35
You need to adjust the paper transfer current on the lead edge. Under "Advanced Paper Settings" item #s 45 and 46 should be what you need to adjust. I used to have a copy of that bulletin but can't seem to find it. (Might have been stored on a Fiery that crashed a few years ago). Your tech should be able to send you a copy of the bulletin.
Thanks. I adjust those settings and improved the quality of the print. It's not completely resolved but it was good enough to finish up a job.
