The balls appear to be in two different colors.
If your client saw this version and insisted that the balls should be the same color and told you to fix the problem - i.e. to make the green and yellow balls the same green color, could you do it?
By the way, the balls are in fact already the same color. Seeing them as two different colors is just an optical illusion.
