danprtr said;
"Surface tension is measured as the dyne level of the print material (usually plastic).
Conductivity usually refers to fountain solution and is a measure of PH (I think).
Assuming the above is what you mean by your question, I believe they aren't "related" since they are referancing 2 separate things."
Surface tension measurement is correct.
Conductivity measurement is incorrect.
Fountain solutions that use alcohol to improve wetting can have their pH measured to judge their effectiveness. Fountain solutions that do NOT use alcohol are very strongly buffered (protected against pH change), and the pH does not indicate or predict their effectiveness.
Conductivity, expressed in siemens (inverse ohms), or in TDS (total dissolved solids) gives a better indication of the condition of the fountain solution.
The original post is a valid question, better if stated "is there a correlation between conductivity and pH..."
If they are unrelated, the plot will be a random cloud of points. If they are strongly correlated a curve of some type will be described.
Good science project...
Larry Goldberg
Beta Industries
Beta Industries: Quality Control for Printers
