Cost of Prepress / (Master) Impression
curveto
I'm curious...
Any thoughts you care to share about your (or industry norms) for expected cost of prepress per (master / first only) impression?
Anicolour cost of prepress
Hello Curveto,
I was recently at an open day at Heidelberg in Brentford, Middlesex, England and they claimed that the on-press startup cost i.e. not including prepress on the computer and proofer; were £10.00 thats ten pounds British Sterling.
This was for four colour plates and one matt varnish plate. The all-over gloss varnish drops off or drips off of the matt varnish. This was plates and make ready for the substrate.
Regards minch.
As a former estimator that amount sounds really low. The number you are looking for is going to vary wildly printer to printer depending on the sophistication/lack of sophistication of the prepress department and the amount of jobs going through it. Higher job volume generally means less per job cost in prepress.
Example: A shop that does 500 plates per day is going to have a much lower per plate cost than a shop that does 50 plates per day.
