More information required.
I don't know if (m)any application(s) can merge pre-separated DCS onto a composite PDF...
We would need some more information of your original CopyDot files. Things like:
- Were they generated on a Crosfield Celsis 6000 series drum scanner, or perhaps on FFEI flatbed scanner (C550 Lanovia or Lanovia Quattro)?
- Which version of C-Dot application was used to generate the DCS? 4.x or 5.x ?
- DCS1 or DCS2 (in latter case: Multi-file or Single file?)
- Which compression algorithm is used: CCITT Group 4 was default, but couldn't be opened on Photoshop of that era. To overcome that, in a pinch someone used PackBits, though it made the sep. files huge, possibly hundreds of megabytes each.
DCS2 Single-file was recommended for most applications.
Admittedly a long shot, but anyway:
Do you still have access to the original scanned files (the "intermediates")? If yes, and if the C-Dot application is also still available, they can be re-processed to more friendly format, e.g. EPS. Mac OS 9 required...
