Interested to hear feedback from other offset printers regarding this digitally optimised paper from Xerox being used for offset printing.
The powers to be have now chosen this as our house stock for all coated ranging from 130gsm up to 350 gsm gloss & silk to be used for offset printing.
Reading xerox's data sheet, it says the coating has be altered & the capillaries are tighter to help dry toner adhesion on digital copiers, also the sheets have been cut sheeted instead of guillotine cut in which they claim reduced paper dust from this. The moisture % content of the paper they say is a lot lower then a coated paper manufactured for offset printing.
With that being said xerox claim it runs fine for offset printing.
Early days yet but I'm noticing three key area's of concern when used on an offset press.
1) A lot more paper dust, especially on the edge of the sheets. The edges of the paper feel rough and look rough under a glass.
2) I need to run spray powder a lot higher to stop set off compared to our normal coated paper range
3) When cutting though a solid there is more bruising/offsetting onto the reverse side.
About the only bonus I see is the ink looks glossier & has less dry back on the sheet. Thinking this comes down to the altered coating not allowing the ink to penetrate as easy.
Regards.
Regards.
