Dot Gain
Depends, is it all jobs or just a job?
Look at your prepress not just in the press room. Could be the water - do you have a reverse osmosis unit? Alcohol balance - test for conductivity.
Bad or old blankets
Print Speed
Roller Pressure too high
Water / Damp Mix
Naff paper and inks will also effect your result
Incorrect linear setting of Platesetter for plate type (Speed/Focus/Power)
Output engine (RiP) not calibrated and then inturn calibrated for the press
Therefore incorrect PPF data going too the press
That's for starters
Dot gain
Dot gain
From an ink formulator's perspective:
Lower the tack (tack is the force to split the ink film-stickiness) of an ink, the higher the dot gain. The higher the film thicknesss of the ink on press (weak ink- lower pigment strength), the higher the dot gain. Over emulsified ink (too much water in ink) will print full. Lower the press speed, the higher the dot gain. Too aggressive fountain solution can break the ink down and it can cause the viscosity and yield value of an ink to go down drastically and it can print too full. Poor transfer from the blanket can result in higher dot gain. If the paper is too porous it can cause higher dot gain.
Hope this helps.
