Double side printing with same image both sides
jricart
Tho original job requested by my customer is to print single sided Badges. He provided a multipage document (500pg) with unique names and pictures on each page. Now he want us to print the badges double sided with the same image/information on both sides.
Is there an easy way to duplicate the pages in order to Impose them using EFI Command Workstation. Any alternative software to make it happen?
Thank you in advance.
If you have Acrobat Professional, you can duplicate all pages of the active PDF by putting this in the Javascript console and executing it:
for (var ThisPage=this.numPages-1;ThisPage >= 0;ThisPage--){this.insertPages({nPage:ThisPage,cPath:this.path,nStart:ThisPage});}
If you don't know how to get to the Javascript console, Google will probably help you out. I think you might have to enable something in the preferences before you can use it.
Once the console is open, delete all of the text in the bottom half, replacing it with the code above. Then select all and press "enter" (not "return" - it has to be the key in the numpad).
Thats exactly what I did and worked fine.
Thank you for all your responses guys!
Or you can extract all pages to each page as their own file and copy paste those, and then right click and combine. I've done it before!
Should read
1
1 (copy)
2
2 (copy)
and so on...
I have a PDF script that allows you to collate two separate files together (every other page). It works great for this usage. You just duplicate the entire pdf file and collate them back together). It also works when you have print spreads that need to be individual pages. You just crop the pdf file into left sides and right sides and then collating them back together. Can't remember where I got the script from but I've had it for a while and it still works.
