PSS Digital Guy
has anyone run #10 or #9 envs on an Iridesse? or A7s?
I'm absolutely unable to run 6x9 or 6.5x9 envelopes... Just does not feed..Yes they run fine, even A2s.
what is causing wrinkling on the trailing edges?, all envsYes they run fine, even A2s.
That is a good question as I see the same thing. Not sure if different brands of envelopes make any difference. For what it is worth it is probably the fuser causing this. It hasn't been that bad or I would have tried different fuser settings, but that might be worth a look.what is causing wrinkling on the trailing edges?, all envs
