Diversified-Systems
Hello All -
I'm currently running several Epson printers on EFI Fiery XF 4.5.8 (I've paid for the upgrade to V5.0 - just waiting for my EAC code to upgrade). I'm experiencing some major color issues and I can't explain/figure out why. I'm hoping someone here can help solve this problem for me.
In EFI I've set up workflows as follows:
1) Created an output device for one of our S70670 Epson 64" Solvent 10 color printers.
2) Using Color Manager created a Baselin (.epl) file using the EFI Color Manager recommendations for ink limit per channel and total ink limit (this is a CT driver).
3) Hijacked the lin and lin-output device and applied the .epl file I created to that lin/output device that was hijacked
4) Without color management on, I've printed P2P targets, measured, imported measurements into Curves 3 and created a vcc file back in EFI Color Manager to reach G7 calibration.
5) Using the .vcc and .epl file (still without color management) I've printed an IT8.7/4 Random test charge and measured/created profiles (tried both my I1Profiler and the built in profiling software from EFI).
6) Connected the ICC profiles to the EPL files.
7) Turned on the Color Management and sent color settings as follows:
Honor embedded profiles when available (checked - because our art department embeds color profiles into our print files that they want us to use).
CMYK Source: SWOP 2006 3V2
Rendering Intent: Relative Color Metric w/ BPC
RGB Source: Adobe RGB 1998
Gray Source: None
Multicolor Source: None
Use PDF Output intent if available (checked - because again we embed ICC profiles into our print files)
Simulation Profile: SWOP 2006 3v2
We print from PDFS that are saved to the 2008 PDF/X-1A standard in Illustrator with output intent set to embed SWOP US Web Coated v2
When I print files I see colors don't match our color calibrated monitors, and customers complain colors are not accurate (which I have to agree with).
We measure the Delta E and see we have some major Delta-e values on colors.
Also, we do a similar process on our older GS6000s and when we print the same file on the different printers, we get different color outputs (even though all the colors in the files are within both print gamuts - SWOP US Web coated v2
Any insight on to what I could be doing wrong would be greatly appreciated!!!
-DS Matt
Gray Source: None
-DS Matt
