heidelberg QMDI stock thickness
Re: heidelberg QMDI stock thickness
I think the spec on maximum thickness on the QMDI is 10 pt., maybe 12 pt. We had two QMDIs and used one to run only 15 pt, which beat it up pretty bad. I traded both for a PressTek 52DI last year and the Presstek will run 15 pt with no problems. I think the maximum spec on the 52DI is a little thicker but 20-24 pt is way too much.
ian
the presstek DI can print upto 20pt, if the option is installed on your press
amin
Canon Research
Canon
Navigating the New Customer Landscape
Enhancing the Print Customer Connection (Part 3)
Read All About It
