We have a canon ipf8000 that has air bubbles in 1 of the ink tube lines.
Things I have tried;
1. A cleaning
2. B Cleaning
3. Nozzle check (some of the lines print, however the color looks kinda green and it should be blue)
4. Re-set the ink tank for that color
5. Checked the connections of the ink tubes and I don't see any leaks, everything looks clean
6. Installed new print head
7. Did another B Cleaning (the air bubbles move a little bit in the lines)
8. Nozzle check (less lines print, however it prints blue)
9. + in the mix of all this I installed another ink tank for this color
I also noticed that the sub tank is only half full, all the other sub tanks are full.
Does anyone have any other suggestions other than calling in a tech?
1. A cleaning
2. B Cleaning
