Has anyone else run into this problem with Illustrator CS5?
When placing a native PSD file into Illustrator CS5 that includes different percentages of spot colors they will be different than what was specified in Photoshop. The spot colors are overlaying CMYK to create a see thru look in Photoshop.
For example if the spot color is 40% it will end up being 16%. 100% will stay at 100%, but any other percentage will be different than what is entered in Photoshop.
We are able to see the difference when creating a PDF or when the file is output to our high end printer. It can also be visually seen when putting an Illustrator CS4 and and Illustrator CS5 side by side.
I can take the same PSD file and place it into Illustrator CS4 or any previous version of Illustrator and they retain the percentages that are entered in Photoshop. Also all percentages match the percentages that are entered in Photoshop when a PDF is created or printed to our printer using any previous version of Illustrator.
I have tried saving the PSD file out as a Tiff file and a DCS2.0 file and get the same results in Illustrator CS5.
Steps to reproduce bug:
Take any CMYK Photoshop File and add a Spot Color (Channel).
Create shapes that are filled with different percentages of the Spot Color.
Place Native PSD file into Illustrator CS5.
Create a PDF.
Take readings of Spot Color percentages in Acrobat using the Output Preview tool.
Percentages are different than what is entered in Photoshop.
Expected Results:
Percentages of spot colors should not be changing.
Is there a bug in Illustrator CS5? We never had this issue with any previous version of Illustrator. Any suggestions would be appreciated.
Create a PDF.
Expected Results:
