Ink Coverage in Illustrator
Re: Ink Coverage in Illustrator
What I do is just save the file as a PDF out of Illustrator and then open the file in Acrobat Professional. In the advanced tab> print production> output preview, here you can check the box at the bottom of the dialog box that says "total ink coverage" and set the value to 230% and all the areas that are more than 230% will highlight in a green color. Then you can go back into your document and change your ink values in those areas.
Bobh
