Re: Ink Coverage in Illustrator
> {quote:title=Jiggy wrote:}{quote}
> For a client I make illustrations in Adobe Illustrator. They switched to a new printer and I've been asked to take a maximum ink converage into acount of cmyk each color max 90% and all together max 230%. As far as I know, there isn't an option in Illustrator to do that? I can't select a colour and that Illustrator automatically downgrades it to below 230% ink coverages, can't I? And I can't save it to eps with max. ink coverage for e.g.
> How is this normally done? Isn't it so that this is done through importing in Indesign and saving it as a certified pdf with the printers job options? That any colours above a maximum percentage are automatically converted to allowed values through this cpdf job option file?
Hi Jiggy,
Illustrator will allow your to apply any level of ink for any vector object, so it is largely a manual task. However there are tools to help.
Firstly, the color profile assigned to the document (Edit -> Assign Profile...) determines the maximum coverage when automatically converting from an RGB/CIE to CMYK color space. For example, a "Newsprint" or "Uncoated" profile will ensure a much lower maximum ink level for an image embedded in the document than, say, a "Coated" one. A quick way to find out the maximum coverage allowed would be to assign a profile then open the standard Adobe color picker and pick the bottom-right corner of the color square (maximum black); the CMYK values displayed can be totalled up to reveal the maximum level for that profile. For example, "Japan Color 2002 Newspaper" allows a maximum of 240% whilst "Europe ISO Coated FOGRA27" allows up to 350%.
By using this system, so long as you pick colors in the color picker rather than using the CMYK sliders, you will always be certain of working within the profile's set limits.
Issues you have to note are the use of transparencies (out-of-the-box, there's no way to discover the resultant ink coverage in Ai), overprinting (which can add ink levels to one or more channels, bumping up the total) and linked artwork (whose ink levels are controlled outside Ai).
The next part is where I get really biased - so please don't read on if you don't think there's any place for self-promotion on forums, even if directly relevant... ;-)
You could make do with our Illustrator plug-in, [Phantasm CS Studio|
http://www.phantasmcs.com/]. This software provides you with not only an Ink Coverage preview tool (to user-defined levels), but also every color adjustment tool gives a "Safe CMYK" option which ensures that all colors do not exceed the limits dictated in the assigned document color profile. The caveats with this, however, remains:
A) Transparencies and overprinted objects which would first need flattening before such an operation could be "automatic".
B) Linked/placed artwork/images can only be controlled outside Ai, so it would be advisable to embed these first if you wish to control them directly within Ai and based on a single color profile.
You can always re-check any changes with the Ink Coverage tool.
Finally, you can view the separations with the quick and full artwork separation tools provided in the plugin.
I hope that this has helped a little.
Best wishes,
Nick
