The wise old press operators of the past, probably all laid off by now or retired, would start up the press and cut back the water until there was just visible scumming on the lead edge of the plate. Then the water would be increased by 5%. That should be the running point.
is there a way to check if printing is overly applied or starving with water? any special control strip i can attach with my color bar? thanks...
Its the mystery of ink and water balance that has long prevented Litho presses from being switched to Auto Pilot
My 0.02c worth
Yes but talk to any press operator 10 years ago and getting correct ink/water balance was a finely tuned art learned over many years and shrouded in mystery as to how it was accomplished much like making samurai swords.
Erik is there anywhere I can find info on this ITB of your's ? I'm just interested in how the concept works..
I can't work out how the ink can be set independent of the water settings..
In my thought's no matter how accurate the ink is transfered onto the rollers,, when ever the ink/fount has to form an emulsion there will always be a direct relationship between the two..
The transfer of ink from the ink duct be it accutate or not is only one part of the many parts that effects the ink/ water balance..
Yes all good stuff, I knew a web pressman in the UK who just listened to the snap of the blanket and paper to tell whether or not he had the correct ink/water balance, loud snap=too dry no snap=too wet, as i say a timed learned skill.
A loud " Snap" equals POOR tension control of the Web - Too much Water results in A WEB Break + and a Blanket Cyl. wrap !!!!!!
Too much Ink also results in --- A WEB Break and a Blanket Cyl wrap !!!
Regards, Alois
