iso12647-2 TVI
Davis.zhou
In ISO12647-2, different screen ruling (lpi) has its own TVI value.
However, in the standard just stated the TVI for 52cm-1, 60cm-1 (150lpi) and 70cm-1 (175lpi). If I want to print a job at 200lpi or higher, what is the suitable TVI value?
Are you sure? The ISO12647-2 copy I have shows different TVI values based on one screen ruling - 60 lcm (Table 5 page 8 in my copy). The different TVI values are stated depending on positive or negative plates, and paper types based on a film workflow not on screen ruling.
thx, gordon p
thx, gordon p
Gordon,
Please see the attachment. Three different screen ruling were stated.
Gordon,
My chart matches the one above, but I believe the current approach is to target the same tone curve (typically the 60 line/cm) regardless of linescreen used. Also US implementation via Gracol is closer to curve B for CMY and curve C for K, while fogra is using curve A for CMY and curve b for K.
Bret
Hint: ISO 12647-2:2004 Annex B Figure B.1 and B.2 (together with Figure 2)
Martin Weberg
