Kodak MatchPrint Server Issue.
PG_Tom
Hi Guys,
So my Kodak MatchPrint Server box died on me. It was a Dell OptiPlex 755. I replaced it with a Dell OptiPlex 745. I used the OptiPlex 745 GHOST CD that came with my Kodak MatchPrint but I'm having issues having the Server Software recognize the dongle. Is there a different driver for the 745 I need to install to work?
-Tom
Ghosting to even a slightly different controller can be problematic, the ghost image is only designed for one particular standard controller configuration.
Try to download drivers for your dongle from here:
Technical Support - Drivers and Developer Kits
Failing that, I would suggest that you download the KPS installer for your licensed version from eCentral.
Regards,
Thank you for your response Stephen.
The Kodak Match Print package came with 3 ghost image DVD's for 3 different systems. one for the Optiplex 755, Optiplex 745 and Optiplex 390.
Since the original box (755) died, I replaced it with a 745 and used the matching Ghost Disk.
So I'm wondering if there are drivers for the Dongle that is different on the 745 vs the 755.
I will try the link you supplied.
Thanks again.
Again Thanks Stephen!
I upgraded the Dongle Drivers and MatchPrint see's the Dongle now.
So I assume the drivers on the Ghost disk for the 745 is older then the 755 and hence the dongle requiring a updated drivers.
Which made perfect sense to me.
