Dear Friends
I have been working on setting of a digital plate on a new violet system. could anyone please let me know the tolerance of dot% on the plate after setting the calibrations.
What is the maximum permitted dot variation on a plate during calibration.
RJ
Dear Friends
RJ
Dear Friends
RJ
The following Applied to Violet Plates:Dear Friends
RJ
Prepress operators are expected to make sure that plates delivered to the press are linear, with a typical tolerance of around 2%.
Calibration is not linearization.
Calibration is required. Linearization is probably not required.
After calibration a press run is done to determine the tone response on press.
That tone response on press is used to build a press correction curve for the plate so that the correct tone response will be achieved on press.
That correction curve may, or may not, make the plate linear.
best, gordo
I removed that post. Gordo, Can you please provide us with detailed information on Dot Gain and Linearization.
