Hi can any member be able to shed some light or have experienced this intermittent problem Our issue is on a Geoman and Uniset cold set presses using coldset inks On start up with new plates we run up to+-200000 copies however we we stop for a edition change only black plates on start up the magenta plate fails to clean up to add to this the plate will clean up but jn some areas the ink will not transfer it looks like the plate has gone blind make new set and back to normal it has happened as well on the Cyan And Black there are 6 other printing sites same presses same ink same fount and plates and paper any suggestions
thanks Bren
thanks Bren
