I was trolling the forums, and I came across a discussion that implied that monitors can be matched to printers. I would like to know more about this, if it's possible.
I had posted in the adobe forum about how my artwork comes back the wrong color from the factory. If this is possible, this may solve my problem!
How can I calibrate my monitor color to match what will actually come out of the printer at the factory?
First off, you need to set your expectation.....can they be matched ABSOLUTELY? Of course not, you're dealing with emissive light (display) vs. reflected light (print).....so there's some very fundamental reasons why they can't be matched in any absolute, measurable way.
Having said that, ABSOLUTELY they can match! (i'm kidding)......but seriously, they can be matched in a relative sense but there's several things you need to be aware of and/or control.
* First off, you need a high quality display (I suggest an IPS panel....NEC SpectraView and EIZO ColorEdge displays are two good display vendors).
* You need a good colorimeter matched to the characteristics of the display...or better yet, put your money in a spectrophotomer like the X-Rite ColorMunki or EyeOne Pro. Spectros have the advantage of being able to be used with ANY display including the newer wide gamut displays....colorimeters, like I said, need to be matched to the display, especially in the case of wide gamut displays.
* You need good calibration software....I would suggest either ColorEyes Display Pro or basICColor Display 4.....and you need to know what calibration parameters (white point, luminance, etc.) will produce the best "soft-proof" color match.
* Viewing conditions are critical....you need a good "D50" viewing booth in order to compare the printed results to your display...I would suggest a dimmable personal viewing booth not next to, but in the general working area of your display.
* Lastly, you need to understand how to soft-proof correctly in your applications, presumably Adobe Creative Suite applications.
The one thing I'm not quite understanding is your use of the word "factory".....are you talking about having the correct color coming from your "factory" printer, like a desktop printer.....or are you speaking of the printing company that's doing your printing as the "factory"? Odd choice of words but I suppose a printing company is like a factory with printed sheets coming off the assembly line.
If it's the former, you would need to profile that printer to sort of "close the loop". If it's the latter, then you need to speak with the "factory" and find out what profile best represents their printing conditions....is it GRACoL Coated1, SWOP Coated3, Newsprint, or some custom profile that they can provide you with?
Just understand that having a quality monitor and calibrating/profiling it is only part of the equation....proper viewing conditions, being able to soft-proof in your applications and knowing what profile best represents the printing conditions of the final printed work are the other factors needed to "close the color management loop" so-to-speak.
It's a bit of a complex answer to a seemingly simple question but I hope this helps,
Terry
