Mimaki JV5 with Triangle Inks Backlit
Jairzinho
Hi everybody
I need some help, im trying to print a White backlit film, but the print is very transparent, as if need it more density. Im using PosterShop Rip.
There will be some special material or some function to be added.
Thanks in advance
:confused:
Try to print double layer, triple layer…JV5 allows to print up to 9 layers with time delays after each pass (I wonder who ever used 9 layers:). Once I printed 4layers on backlit pvc to imitate screen printing). This function could be named "layers" like in TexPrint or "overprint" like in Mimaki's RasterLink or in Photoprint. Must be something like that in PosterShop. It's different from passes. # of layers means each pass printed several times.
By the way, do you use Triangle( JVV ?) inx in cartridges or bulk system?
