We've had a machine since December.We have been using one for about a month and a half. So far it's been perfect and has done everything we have asked of it. It does 60 cpm for 8 1/2 x 11, but we do a lot of 8 1/2 x 11 double sided, it does them much, much slower (my only complaint so far).
I'm not sure how to compare lbs to gsm but I'll assume they're heavy stocks. There is a slow down but not too pronounced - the biggest drop is going double sided or folded.Cool! We're planning to run a good bit of #80 enamel and #100 Cover C2S. What kind of speed are you getting on the thicker stocks?
We use Fiery for our job runs and once in a while I have to run a job in multiple to make pads for customers. If you need say 50 or 100 or any number, and have to run a lot of them and try offset sort from the fiery, there is no place for quantities. So if you need groups of 50 of a page in a offset sort, the only way you an do that is off the glass, which looses a bit of quality from the original.
Lou
