I'm thinking of getting a used DUPLO Docucutter DC-545. Is it worth considering or are there better units in its price range?
I'm looking for a unit that will cut flyers etc, but also be able to do business cards. From what the guy told me at duplo, it looks like the DC-545 can handle a bit thicker stock than in the specs, but the knives might have to be replaced a bit sooner than normal.
anyway, I'll have a look at the link you gave me too![]()
Consider the fact that you could buy a good creaser and a very nice cutter for much less than the 40k+ price of the duplo.
could you recommend some units? Especially for cutting
Ask about the productivity drop when the duplo registers the sheet on the "fly". You could almost cut them by hand with scissors faster.
How much cutting will you be performing (hours per day)? As Craig mentioned, adding the trimming on the Duplo unit may slow its productivity to the point where it does not become feasible. In that case, a lower-cost creaser and cutter will most definitely outproduce an all-in-one solution.
If your cutting requirements are under 2 hours per day, I can recommend our Spartan 185 AEP programmable cutter. It is capable of off-loading some of your shorter-run trimming from the larger guillotine you already have. If you think you will be cutting more than 2 hours per day, then I would think you should call different manufacturers to determine an appropriate-sized guillotine (such as our 23" - Titan 230 or Titan 265XG). Be sure to compare features between manufacturers, as well as long-term resale value for a true ROI analysis.
Titan 230
Spartan 185
Hope that helps!
We have a used Duplo that we have in our shop. We are not using it anymore and are willing to let it go at a very reasonable price so let me know if you are interested in pursuing the Duplo option. It is a finicky little machine and I wouldnt use our model to crease much on the heavier stocks. We got a cheap Count EZ Creaser off ebay a while back and use our guillotine for all of our cutting and creasing needs now. If it will run your paper then it will be fine for cutting though and its definitely a handy machine.
I am sure systems like the Rollem - JetStream or the Rollem - Advantage aren't cheap, but they sure seems FAR superior to the Duplo device if you feel the need for an all in one type finisher.
Does anyone here know the cost of these devices and if they work as good and as fast as they appear to.
