Primesetter 74 Mirror Locked error 14
AntonChan
We have a problem when start up the Primesetter 74, error 14, mirror can't be locked. can someone tell what is the problem?
Fix 4 your problem
Fix 4 your problem
Call Heidelberg support they can help you . . . or i can solve your problem .
All the best
Padrao
I called Heidelberg support, they order some filters for us, what do you think? i hope it 's not the motor's problem...
It is your Vacuum filters(2 small Filters) which cause the generation of the error. Go with their solution
does anyone can tell me how to adjust center punch position in primesetter 74? - the center-punch was a little off center of the image. thanks
Follow the pages 1 to 6 for installation and alignment of center punch on primesetter 74.
Hope this will help!
Enclosed please find the page 6 as attached file.
Hope this will help to resolve the issue! Good Luck!
For the first question: the error is the same like AGFA imagestters tell - spinner did not lock or PLL not locked.
That means the speed of your spin-motor is unstable (based on spinner encoder signals) or did not reach some value of the speed for the certain period of time .
Because Heidelberg's machines use spin-motors with external airflow under pressure for spinner aerodynamic bearings, first of all check air preparation module: air compressor and air filters for the dust, oil and water presence.
In this case Primesetter shows special error about drop of pressure etc.
We could repair this mirror motor of topic starter.
Hi, Mirror can't be locked of the Primesetter mostly cause by Backplane pcb.
if it is error 14 - timeout starting mirror motor
Cause is mirror motor itself or his electronic plates mostly. In several seldom times there was a problem in Backplane MASK pcb. But it is very rarely.
