Prinergy Destination different from InDesign Destination
lnivin
InDesign export to PDF the color is converted to Destination - Coated GRACoL2006 (Adobe version). Using the same Destination Profile in Prinergy, when the same file refines it looks more like USWebCoated than GRACoL.
I expected to get the same result.
Attached are screenshots of Prinergy Color Convert settings and InDesign PDF Export color settings.
I have experienced a radical change in colors when outputting from Adobe Photoshop and Kodak Prinergy. Adobe has reproduced the scanned certificate in grey-yellowish while Kodak's version was in distinctive magenta. Most curate colors were in Adobe version. I think it is due to color conversion engine from Kodak.
If uploading an JPEG image, ensure that the filename extension is .JPG, which maintains the original pixels as long as the file size is under around 3.5mb.
If the exension is .JPEG then the forum software will auto resize to 280px tall.
When you attach files to a forum post, there is a window that lists appropriate file formats, file sizes and whether a file will be resized etc.
