Can anyone explain the process for doing process work
Such as color matching the printed sample. What do you match it to if there is no previous run (new job).
Does the specification specify what the densities should be, e.g. a 50% halftone creates a 65% dot on the sheet? or is the standard density equal, e.g. a 50% dot in the artwork equates to a 50% dot on the finished sheet?
In a shop that has their ducks in a row. The plate setter/press combination, is linerized and calibrated to the shop paper establishing ink densities based on the ink manufacturers recomendations and the paper.
IMHO, in 99% of the cases there is no need to "linearize" the plates before applying a tone reproduction curve (it's a redundant step). Generally the SIDs come first since they are a print industry specification and are integral to the mechanics of the process. The ink vendor will then help the printer select the ink series that performs best at that spec.
best, gordo
What I mean by linearize the plate is running the plate setter base calibration process. This assures that the plate setter is responding to the input signal properly by verifying the plate output against a known target.
The last Heidelberg device I worked with had a target file you imaged on the plate and read it with a densitometer. How else would you know if the plate setter is operating properly?How would one know that the "plate setter is responding to the input signal properly" and what is "known target"? Seems rather ambiguous...can you be more specific?
Terry
There are many CTP plates that do not have a pigment that is measurable with densitometer (In the way that film was), usually the ones that are not dependant on a chemical developer. Some systems have a digital check wedge to verify laser and focus.
And, of course, a densitometer is completely the wrong instrument to use on a plate if you're wanting to accurately read dot percentages. You need a high resolution video/camera type device (CCDot, iCPlate, Techkon Spectro-Plate, etc.) to get an accurate reading....in my opinion at least.
To check if a platesetter is "operating properly" would usually take a technician that's intimately familiar with the device....most of the time a correctly exposed plate in terms of laser energy, maximum run length, etc., is decidedly non-linear.
Once the platesetter is set for correct exposure, you usually need to come back with a plate linearization curve to give you the final "correct" dot percentages, assuming that a linear plate is what you want to start with.
... the laser DOES fluctuate with a dust spec, time wearing down the laser strength, etc. which is why, if you set the base line for just the plates to linear then calibrate per press/paper, you have a mark that you can check for and adjust without having to recalibrate EVERY profile in your system every time the laser fluctuates.
I don't know about now but in the early 2000s Heidelberg (the company David Milisock mentioned) was happy to use densitometers to measure plates. If there is enough contrast between coating and base aluminum they work quite well. (Quality In Print: Using a densitometer to measure plates)
Nooooooo! You come back with a plate curve that gives you the desired tone values on press. Linearity is irrelevant.
