aaronchan
Hi Guys,
I have been working with CMYK printers for many years.
And I have used some RIP with CMYK contone mode with CMYK+ printer for quite some time as well.
But today, I have received a demo copy of Ergosoft RIP, which comes with neither CMYK contone mode nor RGB contone mode. That forces me to start to work in the CMYK+ printing environment.
As usual, I first perform linearization and individual ink restriction.
Here are my densities for each channel:
C & M: ~1.5
Y: ~1.0
K: ~2.0
Or & Gr: ~1.1
I used ColorThink Pro to determine where I should set my individual ink restriction as to how I do it with CMYK only printer.
But when I make a test print for total ink limitation, my paper, which is high gloss RC paper (for test), it won't hold ink more than 220, which produce very bad shadow reproduction. I was first thought maybe I was using too much Light ink in C&M, But no matter how much I've reduced in the dithering setting, the problem still exists.
2 weeks ago, I was trying with Wasatch RIP, which also happens does not have a contone mode for the Epson P7000 as well. And of course, I was facing the same problem with too much ink bleeding with very low TAC.
I have never had this kind of problem before. Does anyone have a successful calibrate and profile an Epson P7000 with halftone mode before? How did you do it?
Aaron
C & M: ~1.5
Y: ~1.0
K: ~2.0
Or & Gr: ~1.1
Aaron
